Serial Port - RS 232 - Error
Hi Again !
this is the second error I hit ! it is again given in the picture !
best regards
Message Edited by Support on 11-13-2007 12:58 PM
(2,751 Views)
Are you sure the command starts with the quatation mark? And are you sure of the termination characture?
Also make sure you have baud rate, stop bits, parity set up correctly for the instrument.
Have you tried sending this command with Hyperterminal? This will tell you if it's a problem with the instrument, the port or your LabVIEW code.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(2,744 Views)
