Serial Read parsing data works correctly but polarity and decimal point placement not working
I am new to labview and working on a project that accepts seral data. I am reading the information and parsing the data correctly but when I try to put the number together the polarity and decimal pt do not seem to be correct. When the polarity is negative, a 1 the number that is output is positive. I posted before and was directed to use the concatenation and the power of 10 and I question whether this is correct. Should I just be checking for the 1 (negative bit) and negate the number at the end before output?
I have another question: How to accept a number from the touch panel and just write that number to an output file? I searched in the help and online but could not find an example.
Any help would be appreciated.
I have included my vi.
Thank you
(2,955 Views)
Hi gprall,
please stick with your original thread, don't create double posts!
Here I already told you to rethink & check your sign conversion routine!
(When you create a double post you should not only attach your VI, but also a description of the communication protocol - as you did in your original thread. Without that protocal description your question is too vague…)
Which "touch panel" are you talking about? There is no "touch panel" in your VI…
(2,950 Views)
Accepted by gprall001
Sorry, I apologize. I thought since this was a new problem that a new post was required. I fixed the problems addressed in this post myself. Oh and when I created the project/vi I created it as a touch panel project.
Thanks again.
(2,909 Views)
