My first inclination would be to check to make sure that the serial port
you are trying to initialize has any errors on the NT machine. Check
the error number coming out of the Serial Port Initialization VI and see
if it isn't 0. A number other than zero indicates an error. There may
be something else using the serial port.
If you right click on the Serial Port Initialization VI and bring up the
Online Help, it will tell you what the valid numbers for serial ports
are for Win 95, 98, and NT. (They're all the same.)
Mark
In article <39abb87f$0$12796@businessnews.de.uu.net>,
"Holger Decker" wrote:
> My application (including serial communication) works fine under
Win95, 98
> but I can't establish an communication under WinNT 4.0 W
orkstation
(SP5).
> What can I do??
> Thanks
> Holger Decker
Sent via Deja.com http://www.deja.com/
Before you buy.
