Serial port not working anymore...problems with Windows XP?
I wrote a program that communicates through a serial port and it worked fine on my computer at my desk (which runs Windows 2000) and the executable of that program worked fine on other computers also running Windows 2000.
However, when I loaded the executable onto a laptop PC with Windows XP, the program runs but it won't communicate. Anyone else seen this problem before?
Amateur programmer for over 10 years!
Message 1 of 44
(47,047 Views)
Here's some more info...on my development PC and on the PC's where the serial port does communicate, I have serial cards that connect to mutliple serial outputs. So in that program, the VISA resource names are set up as "ASRL1::INSTR", "ASRL2::INSTR" and so on.
On the laptops running Windows XP, they have a standard card with only one com port. So I set up that version of the program to use COM1 as the VISA resource name. I also made sure that the baud rates, stop bits, etc. all matched up. That didn't seem to help.
Any ideas?
Message 2 of 44
(47,029 Views)
Have you done the loopback test which is decribed in "Serial Communication Starting Point"?
Message 3 of 44
(47,012 Views)
The first Q I ask when a laptop doesn't talk serail but the tower did is,
Do you have a good ground?
Towers find a ground through the chassis.
Laptops float rlative to ground.
Ben
Message 4 of 44
(47,011 Views)
I suggest checking that the laptop does not have any other program running that may take over the serial port. Common suspects are PDA synchronization software or GPS software.
Allen Weekley
allen@weekleyconsulting.com
Message 5 of 44
(46,995 Views)
I'm not real familiar with XP, and neither am I very familiar with the software that usually runs in the background. What kind of programs should I look for when I pull up the Windows Task Manager that might take over the serial port?
Message 6 of 44
(46,975 Views)
Use hyperterminal to communicate with something through the port. If you can, the port is free and the problem is apparently on the LV side. Try putting the Serialdevices... line into your exe's INI file.
___________________
Try to take over the world!
Message 7 of 44
(46,963 Views)
The com port was tested with a Windows com port testing program and the port does work.
You'll have to explain your last statement about the Serialdevices line.
Message 8 of 44
(46,957 Views)
Well, I've found that getting an executable with serial comm in it to work might turn out to be a mini Via Dolorosa but try the following:
1. First, create an installer and make sure you include serial support in it.
2. Next, install MAX on the target machine. I'm not sure if this is necessary, but it helps.
3. Put the following line in your INI file, just to be sure:
serialDevices="COM1; COM2; COM3; COM4; LPT1;"
4. Hope.
___________________
Message 9 of 44
(33,518 Views)
Hi Spaceman:
Are you able to communicate with your instrument by opening a VISA session in Measurement and Automation Explorer? Please test this out first.
Thank you,
Emilie S.
Message 10 of 44
(46,945 Views)
