Serial port not working anymore...problems with Windows XP?
I tried to use the Hyperteminal in echo mode and it gives me only one character i sent which on the working pc is two.
and nothing that i type appear if i disconnet pin 2 and 3.
Can you see what is going on?
regards,
tes
Message 41 of 44
(5,097 Views)
Ben I'm having the same problem, my laptop (Dell Latitude 620), the serial port doesn't transmit, it receives ok, using hyperterminal (XP). you mentioned a floating ground, how can this be resolved, will just a ground connection work, or do I need to create some type of a ground protection device as well.
JakTrak
Message 42 of 44
(1,694 Views)
Hello
I am having the same issue. I am presently running a test for a different compenent with same functionalities using the same program(which has the issue) and the program runs fine.
- I copied my present program from the old computer (windows XP) to new computer (windows 7) changed all the required communication settings to talk to an AG 34980a.
- I was able to talk to the DUT's using a communication VI , but when i started the Main Test VI the program stops and cannot connect to the DUT not going any further once it hits serial port ICON.
- I use IO agilent library to see if the correct output is scanned to the correct channel from the DUT as requested.
I am using Labaview 2011 on both old and new test computers, any changes that I can make to fix this issue?
Message 43 of 44
(1,206 Views)
vinithanalla - I had similar issues transferring a VISA read and write program that worked fine in XP to a computer running Windows 7.  What finally worked for me was I created a small VI that merely opened the COM port session, flushed the I/O buffer, did a CLR, then CLOSED the COM port.  I ran that VI one time, and after that all my com port issues went away.
I wish I knew for sure what had happened, but my best guess is something grabbed a hold of my COM port in the background and wasn't letting go, despite rebooting the computer and everything, until I ran that little VI.  Give that a try.
Amateur programmer for over 10 years!
Message 44 of 44
(1,197 Views)
