Serial port with VISA
I am trying to use the serial port with VISA... but nothing is
working! I look at the example, but it gives me a error in the firt
sub-VI (visa serial).
Does something special is needed to run those examples?
Thanks!
Alexis
(2,779 Views)
1. You must setup VISA drivers first. It is ussual problem when someone tries to use VISA functions without installed driver. To install driver you must run your Labview install disc and check this option there.
2. Also check if your COM ports are enabled in BIOS and in Control Panel->System->Device manager.
3. And then check how VISA works in MAX.
Good luck.
Oleg Chutko.
(2,779 Views)
