Serial read LabVIEW: Error overrun
I have to read  bytes from a PCB board, which is sending 20bytes every 10ms. The 20 bytes have a protocol attached to it, so I am confined to read a single byte at a time.
Because of this I am getting at overrun error. I played with my buffer size and increased it, but no luck. The baud rate is 115200.
Is there any other way, I could modify my program, so I wont face this problem?
Please find attached
Message 1 of 13
(6,454 Views)
Hi looser,
This one is ok!
Why? Can you explain this sentence?
Sure!
Read the full message with just one VISARead function!
- You configured the serial port to use the default TermChar. Does your "PCB" send messages terminated by a LF char? If that is the case you should simply call VISARead with 32 bytes to read: it will give you the full message!
- Parse the message once you read it. You can use any string or array function to do so!
Recommendations:
- Use Autocleanup more often!
- Always show the display mode indicator for strings (and numbers), when you don't use the default display mode!
Message 2 of 13
(6,444 Views)
Protocol to identify the corresponding bytes.
The header, length, data, check sum and a dummy value.
The header is important to identify the start of the message, length gives the lenght of the data I want to read, data is say the values I want to read (for example say a sine wave), next chk sum to ensure the length and data is interpreted properly, dummy value is just an additional byte for future use.
I dont want to read the full message at once, as I want to keep checking the header, length and chksum regularly to ensure the proper message. Reading the full message will void me of this checking and I would not have an idea, if the info is good or not. I dont have a termChar. So I left it blank.
Message 3 of 13
(6,438 Views)
Accepted by looser_engineer
Hi looser,
But that will improve processing speed quite a lot and will avoid buffer overruns!
You can do this with full messages too!
Why do you think so???
Then you should configure the serial port differently: you need to disable the TermChar! Please read the LabVIEW help for this function!!!
For reading a datastream from serial port you should do like this:
- Read a block of bytes like 20 chars from the port
- append those 20 chars to previously read data
- search for your "Start of message" char in the collected stream data
- split the collected string at that marker, anything before that marker is an older message, anything after will be the next message!
- keep appending new chars by starting this algorithm over!
Message 4 of 13
(6,435 Views)
I see your bullet points. Won;t it be too much math?
Could you please post a VI to read say 20 bytes and save it in an array ? Preferably converted to Decimals
With NO While loop
Message 5 of 13
(6,429 Views)
Hi looser,
No…
At 115200baud you will receive at most 11500 bytes/second. At 20 bytes/message this will be less than 600 messages per second: any modern computer can handle this!
Once you have your message (of 20 chars) you can stuff it into a queue and use a producer-consumer-scheme to parse them. This will decouple the communication loop from your "hard math" loop and will improve performance even more…
Message 6 of 13
(6,411 Views)
I was thinking something like int he attached file would work?
Message 7 of 13
(6,407 Views)
Just a rough sketch…
Message 8 of 13
(6,401 Views)
I updated my similar to your suggestions and probably employ the data manipulation soon. However I am still getting the error over run when I initially start the code. The error shows up for first two iterations and the code works like a charm after that. I believe it is because I did not close the port. Could you comment please?
Message 9 of 13
(6,385 Views)
Hi looser,
Yes!
- You also forgot to implement any error handling at all!
- Calling VISAClear before opening/configuring the serial port is kind of silly…
- You still have not implemented my suggestions from above regarding display modes of string (and numeric) constants!
Another suggestion:
When your loop should run as fast as possible you should not update any indicators in your loop. What's the point of displaying "header, length, data" in a string indicator when those strings will rush in at ~1500 updates per second?
Message 10 of 13
(6,341 Views)
