Set HP3478A Front/Rear in LabVIEW
I want to take measurements using both the front and rear inputs on the HP3478A Multimeter. This is done easily with the hardware front/rear switch. The state of this switch may be queried by using the 'S' command, where a 0 indicates rear and 1 indicates the front.
Is it possible to set the state of this front/rear switch using LabVIEW?
(3,582 Views)
What does the programmer's manual say?
(3,561 Views)
Hi blaffie,
manual page 3-13 says it all…
(3,555 Views)
Accepted by blaffie
The manual clearly states that status is a read only.  It is a hard switch after all (in or out).  I would recommend using some relays to change your signals if you really need to hook up different things for measuring.
(3,553 Views)
