Set Report Orientation VI Broken on Mac
I am making a cross platform VI in Labview 7.0. It uses the Set Report Orientation.vi to make the page landscape. The VI works fine on the PC. On the Mac there is a corresponding Set Report Orientation.vi, that does nothing, however the VI comes up with errors (Wire has loose ends) When I try to edit the block diagram to fix it, it asks for a password. Where will I find this password?
-Kirk
kirk.crawford@aero.org
(2,430 Views)
Hi Kirk,
This is a known issue with the Set Report Orientation.vi on the Mac. According to notes written by R&D, the VI was not supposed to be included on the palette. The reasons were not indicated, but I have contacted the engineer regarding this issue and will try to get more information for you.
Thanks again for contacting National Instruments and have a great day!
Kileen C.
(2,430 Views)
