Set an element in boolean array as the selected case for a case structure
I am quite new to LabVIEW. I am trying to get the Internal state change status register(INR) of the oscilloscope, which is in decimal format and convert it into a boolean array. When the 8th element of the array is "true" I want to read the signal area. I already have extracted the INR as a boolean array and I have set the case structure to read the area. How can I set the 8 th element as the case selected?
Thank you.
Message 1 of 10
(2,430 Views)
Accepted by dachal1
Index the 8th element of the array and wire that to the case selector.  If you want the case structure to trigger on the results of the 8th element of the array, that is.
Bill
CLD
(Mid-Level minion.)
Message 2 of 10
(2,425 Views)
I'm surprised you're stuck on this and not the conversion to the array of Boolean values.  To me, that would be an advanced topic, so kudos to you for figuring that part out.
Bill
CLD
(Mid-Level minion.)
Message 3 of 10
(2,422 Views)
I have 1D(true, false) array now. How can I index the 8th element? Can you explain it little bit more?
Thank you.
Message 4 of 10
(2,419 Views)
Thank you.
Look in the array palette to find the "Index Array" node.  Part of programming efficiently with LabVIEW is knowing where to look for things.  I was hoping you could take my lead, but here, I've given you a better hint.  🙂
Bill
CLD
(Mid-Level minion.)
Message 5 of 10
(2,387 Views)
Thank you.
Message 6 of 10
(2,382 Views)
Accepted by dachal1
Also be aware that array indices are zero based, so the 8th element will have index seven.
Unless you needs that boolean array elsewhere, it is wasteful to inflate you data structures to use 8x more memory. You can check the bit #8 equally well directly in the numeric by doing some cheap bitwise operations. (In fact, you can wire the masked numeric directly to the case structure and name the case 128 and the other default)
Message 7 of 10
(2,369 Views)
Accepted by dachal1
@altenbach wrote:
Also be aware that array indices are zero based, so the 8th element will have index zero.
On the other hand, at least IMO, the first method is more self-documenting and easier to understand at a glance.  Also, you can't avoid converting if you want to display it as either an array or converted into a typedef'd cluster.
Bill
CLD
(Mid-Level minion.)
Message 8 of 10
(2,366 Views)
Accepted by dachal1
Yes, of course sometimes you want to display the boolean array.  Often you even want to reverse it so the LSB is on the right and it looks similar to the number displayed in binary.
My "blue" method is easier to read if you display the constant in binary.
You can even make it scalable to set the bit to be tested at run time 😉
Message 9 of 10
(2,356 Views)
Thank you.
Message 10 of 10
(2,330 Views)
