Set color to an Array Cluster
Is there a way to set the color if the array, cluster, font, etc, to a specific column and row within an Array Cluster? Looking at the properties and methods, it does not appear so. Do I have any options other than redesigning my VI?
Below is a example of how my data is set up with example data provided.
I'd appreciate any advice.
(2,844 Views)
Accepted by Eric1977
Interesting that you should bring this up.  Coincidentally, a similar question was answered just a little while ago:
https://forums.ni.com/t5/LabVIEW/Change-enum-colour-in-a-cluster-that-is-in-an-array/m-p/2918506#U29...
Check out Jeff's answer and see if maybe you can adapt it to your problem.  🙂
Bill
CLD
(Mid-Level minion.)
(2,840 Views)
