Set color to an Array Cluster
Is there a way to set the color if the array, cluster, font, etc, to a specific column and row within an Array Cluster? Looking at the properties and methods, it does not appear so. Do I have any options other than redesigning my VI?
Below is a example of how my data is set up with example data provided.
I'd appreciate any advice.
(3,197 Views)
Accepted by topic author Eric1977
Interesting that you should bring this up.  Coincidentally, a similar question was answered just a little while ago:
https://forums.ni.com/t5/LabVIEW/Change-enum-colour-in-a-cluster-that-is-in-an-array/m-p/2918506#U29...
Check out Jeff's answer and see if maybe you can adapt it to your problem.  🙂
Bill
CLD
(Mid-Level minion.)
(3,193 Views)
