Set programmatically a transparent BG color of indicator
Hi forum,
I created a csv file where I can set all visual parameters of my GUI (caption, default value, visible, size, colors, ...).
With this file, I also set the forground and background colors, but I don't know how to set a transparent color.
Is there a way to do this?
Thank you in advance for your help!
Julien
(1,046 Views)
@Gub156 wrote:
Hi forum,
You can use the following snippet, probably:
(1,041 Views)
Hi Andrey_Dmitriev,
Thank you for your answer. I tried your solution, but it doesn't work. I can change the background color to transparent, but to get a real transparent indicator, the frame if the indicator needs to be changed as well.
The only way that I found to do this is to use the tools palette and change manually the color of the frame.
This is what I get with your example
And this is what I want:
Thank you in advance for your support!
(986 Views)
Accepted by topic author Gub156
@Gub156 wrote:
Hi Andrey_Dmitriev,
Thank you for your answer. I tried your solution, but it doesn't work. I can change the background color to transparent, but to get a real transparent indicator, the frame if the indicator needs to be changed as well...
Why do not use Simple Text indicator from Classic Palette:
You can easily make it "frameless" (see my attachment in previous comment)?
(977 Views)
