Set tabbing order within a tab
I am in labview 7.1.
I have a tab control, and within that tab control I have two tabs, each with 4 numerical controls.
When the user presses the tab key, I want the editing indicator to move from left to right among the 4 visible controls, and instead its moving haphazardly throughout them
I found the way to do it normally, Edit -> Set Tabbing Order, but that doesn't seem to let me specify inside the tab, only outside it. It counts the tab control as one control, and doesn't let me set the inners.
Suggestions?
thank you
(6,435 Views)
Accepted by bobholmgren
I hate when this happens... I found the solution almost instantly after I posted this.
Right click on the tab, then click "Reorder controls in page," then choose the order.
(6,432 Views)
Nice.  State a problem then the solution, then give yourself the credit and a pat on the back.  Smiley Very Happy  Just kidding you bobholmgren.  I thought it was rather funny after reading the etiquette post
- tbob
Inventor of the WORM Global
(6,419 Views)
I was like "crap."  Figured I'd post the solution and mark it, that way if someone has the same problem, they'll hopefully find the solution right there, and then others would see it as a marked solution and not open the thread trying to help.
(6,413 Views)
