Setting Global Variable order
Accepted by topic author emw129
@emw129 wrote:
Here is a screen Capture of my Global Variable Tabbing Order.  Under Edit -> Tabbing Order is grayed out
Why
Because you have something selected.  Deselect everything from your front panel and try again.
Message 11 of 12
(1,106 Views)
The global Variable Tabbing Order was being disabled by the Tab control.  Apparently you can't set TAB-ing if your Global Variable VI contains a Tab Conrol.
Message 12 of 12
(1,078 Views)
