Setting Limit for Data and Reset to Zero
I have a LabVIEW script that takes input from a voltage source (and several other sources), converts it to its actual value, and displays it to the user. What I would like to do it set an upper limit which says that if the voltage/other variables reach their limit, it will reset the voltage/other variables to zero. Ideally I would also like to continuously collect this data to a file until the voltage supply is turned off. Attached is the VI of what I've already written if it helps.
Thank you!
(1,183 Views)
Not sure what a "LabVIEW script" is, but could you save your VI for previous so more people can actually look at it? Thanks! What are "variables"?
(1,147 Views)
The variables are voltage, pressure, current, and radiation.
(1,103 Views)
I don't know if what I said was clear enough so here's an example: I have a voltage source and I want to continuously read these voltage values (I am doing so using a USB-231 if it's pertinent) and have them written to a file. If the voltage were to reach 250kV, I would want the voltage to reset to zero. Same for all the other variables I mentioned, but with different limit values. I am unable to revert my VI to a older version of LabVIEW but when I can do so I will attach it for reference.
(1,094 Views)
