Setting RS232 control lines programmatically
I'm also confused as to what TCP/IP has to do with the serial port.
Message 11 of 12
(523 Views)
Ok lets get started now.
1. I am having a server PC where Virtual MODEMs have been configured using Virtual COM ports.
2. I am the client where I am simulating another MODEM.
3. I am sending some AT Commands to initialize the MODEM on the server side to start my actual communication.
------- This all is done using TCP/IP as there is no hardware present.
4. Now I am making a call to Server MODEM for that I am sending 'RING'...'RING'.... commands.
5. Now for server MODEM to accept the incoming call first it should know some call is coming to it.
   So when I set the RING INDICATOR high only then it will accpet the incoming call.
See the control lines of the Server MODEM:
Message 12 of 12
(517 Views)
