Setting a Threshold Array
I've looked and looked on how to do this in on the forums but no luck.
I'm working with larger data sets. The code below is a simplified version of what I'm trying to do.
I have a 2D array that gets converted into a 1D array to make taking the average easier.
I want to create a new 1D array whose elements are above a threshold that I define. The size of this new array may be smaller. Every time I try to eliminate the elements below the threshold for those values below the threshold, a zero is put into the new array. This will effect the average.
Can someone help. As I just want the values below the threshold and no zeros.
Cheers.
K
(6,388 Views)
It is time to call in the bucket brigade.  See the example.
(6,386 Views)
Darin.K
Could you please repost for labview 8.2.
Thank You
K
(6,383 Views)
Accepted by Kamilan
(6,377 Views)
