Setting up RFID system
My main concern is VISA configuration. I am able to send a string, but it seems there is no return string in this case a respond. What I am sending can be referenced in Pg 14 from the attachmnet below.
Message 11 of 15
(1,928 Views)
Hi jp978,
Do you know if your device is able to communicate properly with VISA? Have you tried and established this with a more simple case?
Message 12 of 15
(1,910 Views)
I have looked at some of the examples, but dont quite know how to apply a simple test to this RFID reader. I don't think the manual provides a test case either.
Message 13 of 15
(1,906 Views)
Hi jp978,
I understand how this can be frustrating and I commend you for your effort! My recommendation for a best first step in troubleshooting would be the need to ensure that a proper connection has been established and that your device is communicating properly with VISA via *IDN or some other method of communication being that the application is not functioning as expected. Once you know that the device is communicating as expected with your computer then I would recommend trying to apply a simple test to the RFID reader.
I hope this helps!
Message 14 of 15
(1,894 Views)
Quick Update:
I managed to get correct readings from the tags. I verified the EPC with the UHFreaderDemo provided by the manufacturer.
I will also post my code for anyone that may want to take a look, as soon as possible. In my case I only wanted to run an inventory command and read tags within range.
 Thank you guys for the suggestions and help.
Message 15 of 15
(1,886 Views)
