Setting up a stop watch
The stopwatch is still not working as its supposed to. Is there a way for me to make sure that it counts continuously and as not dependent on the time for the input data to be acquired? Any suggestions with this will be very much appreciated.
Message 11 of 14
(2,053 Views)
You already had done this. Just put it in a separate loop. A small modification you should make is to put a wait (msec) in the loop. No need to run the loop as fast as possible.
Message 12 of 14
(2,038 Views)
Thanks for your suggestion, but if I put the stop watch in a separate while loop, won't I have 2 stop buttons then? Is there a way to ensure that I have only one stop button and when I press stop, both loops terminate?
Message 13 of 14
(2,033 Views)
There are a number of ways. Simplest in your case is to just create a local variable of the stop button and place the local inside the other while loop. You cannot create a local from a Boolean with a 'latch' action so change the mechanical action to a 'Switch'.
Message 14 of 14
(2,029 Views)
