01-30-2009 12:47 PM
01-30-2009 09:06 PM
I would suggest you try this first
LabVIEW in 6 hours - http://zone.ni.com/devzone/cda/tut/p/id/5241
In case you are feeling a little lazy try LabVIEW in 3 hours - http://zone.ni.com/devzone/cda/tut/p/id/5247
The course also covers some based DAQ stuff. You can also try the this example <labview folder>\examples\DAQmx\Digital\Generate Values.llb\Write Dig Chan.vi
Amit
02-02-2009 11:03 AM
Another great resource is the help files and example finder in labview. To access the example finder go to: Help--> Find Examples, a window will pop up (let it load fully) and you will be able to navigate trhough many different examples including data acquisition and switch configurations.
Don't hesitate to post back with questions once you start to get going with the programming.
Hope this helps!
