Setting up cdaq with 9472
Hi I am new to Labview, but I have a question on how to setup my Cdaq with two 9472 modules. Just to get use to coding, I would like to have a simple switches (16) that would turn on each of the channels. Unfortunatly, your directions would have to be real simple, step by step. I'm still trying to get use to the whole thing. Thank you for your time.
(3,293 Views)
I would suggest you try this first
LabVIEW in 6 hours - http://zone.ni.com/devzone/cda/tut/p/id/5241
In  case you are feeling a little lazy try LabVIEW in 3 hours - http://zone.ni.com/devzone/cda/tut/p/id/5247
The course also covers some based DAQ stuff. You can also try the this example <labview folder>\examples\DAQmx\Digital\Generate Values.llb\Write Dig Chan.vi
Amit
(3,283 Views)
Another great resource is the help files and example finder in labview.   To access the example finder go to: Help--> Find Examples, a window will pop up (let it load fully)  and you will be able to navigate trhough many different examples including data acquisition and switch configurations.
Don't hesitate to post back with questions once you start to get going  with the programming.
Hope this helps!
Charley Dahan
Global Account Manager
(3,258 Views)
