Several charts with one x-axis
Hi everyone Smiley Happy
Here is my question: currently I have 4 separate waveform charts having the same x-axis (current date and time).
What I want to do is to plot these 4 waveform charts one above the other with only a single x-axis at the bottom, is it possible?
I don't want the 4 curves on the same chart.
Thank you in advance for your replies and have a nice day!
Message 1 of 8
(3,352 Views)
Have you tried to wire a 4 element cluster to the y axis of the chart?
Message 2 of 8
(3,340 Views)
make an array of waveforms of it and try the mixed signal graph
right click in the plot area and add plot areas
you can distribute the plots on the graphs via drag and drop at the legend or by property notes
Greetings from Germany
Henrik
LV since v3.1
Message 3 of 8
(3,320 Views)
maybe this will help...
Spoiler
Message 4 of 8
(3,312 Views)
Hi Rafale,
You can just bundle the signals with a bundle function like this:
On the front panel, right click the chart and select stack plots. The multiple plots in the chart will now be shown in multiple plot area's within the same chart with only one X-axis.
Let me know if this is what you mean and wheter you have any questions left.
Rik Prins, CLA, CLED
Software Development Engineer
Message 5 of 8
(3,293 Views)
Accepted by rafale350
Hi Rafele,
Little addition to my previous post. See the solutions for a waveform datatype below:
 The build array function needs to be set to concetenate inputs.
Message 6 of 8
(3,288 Views)
Thank you for your answers!
Problem solved! Smiley LOL
Message 7 of 8
(3,275 Views)
Any time! Good luck with the rest of your application.
Message 8 of 8
(3,267 Views)
