Share data cluster between two loops?
I realize it is friday afternoon, head not working so fast anymore.Smiley Frustrated
I have a fairly big data cluster (100k data points altogether) that I use in the main loop, keep it in shift registers, adding/changeing data over time.
Now I like to read some of that data also in another loop, but did not find a good solution up front. It feels like it is a schoolbook example, and therefore I thought someone more clever than me might see a good solution directly! Smiley Happy
Message 1 of 10
(5,702 Views)
If you are running 2016, you might consider using channel wires.
Message 2 of 10
(5,688 Views)
Accepted by topic author Ola_A
See here for a nugget I wrote on Action Engines.
If you are not familiar with them read that nugget and imagine moving your shift registers into a sub-VI that can be accessed from more than one loop.
It will cleanup your diagram a bit as well.
Ben
Message 3 of 10
(5,687 Views)
Functional global maybe?
aputman
Message 4 of 10
(5,686 Views)
Sorry, I am at labview 2015, and need to compile at LV2012 in the end...
Message 5 of 10
(5,665 Views)
With the assumption that you are only updating the value in one place and your other processes just need to read the latest value (do not care when it updates), I give you 2 options:
1. Data Value Reference (DVR)
2. Global Variable
If you are dealing with a large amount of data (I would put 100k data points in that category), I would go with a Data Value Reference (DVR).
Message 6 of 10
(5,636 Views)
Crossrulz, how would I code a Data Value Reference if I like to keep my shift register? The quick tests I just did suggested I need to make a new reference for each round in the main loop, and somehow transfer that reference to the other loop.
Ola
This vi does not work at all...
Message 7 of 10
(5,591 Views)
You need to create the DVR before both loops and pass the reference into the loops.
Message 8 of 10
(5,585 Views)
I understand the simple example, and is there a way to use a similar approach to read data that is stored in a large shift register?
Message 9 of 10
(5,577 Views)
Just make sure the data type of the DVR matches that of the shift register and it will work exactly the same way.
Message 10 of 10
(5,560 Views)
