Shared Variable Timestamp fixed on TPC-2012
My code running on a TPC-2012 reads from a shared variable that is hosted on a CRio.  Reading the timestamp of the shared variable gives me the same 5AM time in 1903.
If I read that same shared variable using software running on a PC vs the TPC, I get a timestamp that corresponds to the correct time on the CRio. Therefore, the CRio is publishing and updating the variable as required.
What is up with the TPC?  I am guessing that reading the timestamp is not supported on the TPC?  Yes/No?
(3,494 Views)
Accepted by topic author dbtestcon
Fixed.
You must read the timestamp AND the actual variable output.  Just reading the timestamp will not give you anything meaningful.
I didn't care about the data in the Shared Variable, I just wanted the tmie it was written.....
(3,464 Views)
Hi dbtestcon,
This was reported to R&D (#162395) for further investigation.  Thank you for posting your workaround.
Jennifer R.
(3,442 Views)
