Having trouble assigning the Data Type to Shared Variables
I have some type definitions that I need to use as shared variables.  When making the shared variable, I create it and then name it.  I then select "From Custom Control..." in the Data Type field and select the applicable type definition.  The problem is that it displays some other type definition.  Am I doing something wrong?  I am using LV v.8.6. I don't recall having this problem with v.8.5.1.
(2,889 Views)
Do you have your custom controls set as type defs or strict type defs?
(2,866 Views)
Hi Hunter,
All the custom controls are set to Type Def.  Since sending my question, I noticed that the system uses the first similarly used custom control and it's name.  For example, I have several clusters that each have four numeric controls in them.  When creating a shared variable for each of the various clusters, it uses the first custom control that was set up as a shared variable.  I hope this makes sense to you.  I have not had a chance to see if the shared variables are working because I have other issues to deal with first.
What troubles me is that I don't recall seeing this with v.8.5.1.
I suppose I could and perhaps should use a common type def for all similarly used shared variables.
Dave
(2,857 Views)
A Common Type def will make things much easier down the road especialy if you decide to make changed to the data type.
Hunter
(2,839 Views)
