04-22-2009 09:47 AM
i would like to know how to transfert selections from a cluster of ring menu into a string array ?
here a starting vi
Best regards
Tinnitus
Solved! Go to Solution.
04-22-2009 10:17 AM
04-22-2009 10:51 AM
tinnitus wrote:here a starting vi
That's not really much of a start... ![]()
aeastet:
I think Tinnitus actually wants just the displayed values, rather than the whole list of values. In this case you would actually want the RingText.Text property. Also, you don't need to use Build Array with a shift register. Just autoindex the values out. If you needed to get all of the possible values you can just reshape the resultant 2D array into a 1D array after the loop.
04-22-2009 11:31 AM - edited 04-22-2009 11:32 AM
Thank you both,
Aestest -> not excatly but idea was here +1
smercurio -> good answer and quick +3, -1 for sarcastic remark = 2 , a start is a start , isnt it ?
Best regards
Tinnitus
Sorry i can't make more than one kudo !!!, is it new ?
04-22-2009 12:18 PM
tinnitus wrote:Thank you both,
Best regards
Tinnitus
Message Edité par tinnitus le 04-22-2009 11:32 AM
Yes it is kinda new.
We had the system converted after years of people assigning negative ratings to replies from volunteers.
Ben
04-22-2009 05:02 PM
Thank you ben for kudoing
regards
Tinnitus
