cluster of ring menu to array of string
i would like to know how to transfert selections from a cluster of ring menu into a string array ?
here a starting vi
Best regards
Tinnitus
CLAD / Labview 2011, Win Xp
Mission d'une semaine- à plusieurs mois laissez moi un MP...
RP et Midi-pyrénées .Km+++ si possibilité de télétravail
Kudos always accepted / Les petits clicks jaunes sont toujours appréciés
Don't forget to valid a good answer / pensez à valider une réponse correcte
(3,694 Views)
(3,686 Views)
Accepted by topic author tinnitus
tinnitus wrote:
here a starting vi
That's not really much of a start... Smiley Very Happy
aeastet:
I think Tinnitus actually wants just the displayed values, rather than the whole list of values. In this case you would actually want the RingText.Text property. Also, you don't need to use Build Array with a shift register. Just autoindex the values out. If you needed to get all of the possible values you can just reshape the resultant 2D array into a 1D array after the loop.
(3,670 Views)
Thank  you both,
Aestest -> not excatly but idea was here  +1
smercurio -> good answer and quick +3, -1 for sarcastic remark  = 2 , a start is a start , isnt it ?    :smileyvery-happy:
Best regards
Tinnitus
Sorry i can't make more than one kudo !!!, is it new ?
Message Edité par tinnitus le 04-22-2009 11:32 AM
(3,652 Views)
tinnitus wrote:
Thank  you both,
Best regards
Tinnitus
Yes it is kinda new.
We had the system converted after years of people assigning negative ratings to replies from volunteers.
Ben
(3,643 Views)
Thank you ben for kudoing
regards
Tinnitus
(3,610 Views)
