Shared Variables - Properties
I have a couple of questions about properties of Shared Variables (SV). They can be configured either by using the dialog box (right-click on SV -> Properties), or programmatically via the "SharedVariableIO" property node. Have a look at the NI-Examples to see how SV can be created programmatically by using the DSC module.
1)  The dialog box offers a property "Variable Type" which can be "Network-published", "Single-Process" or "Time-Triggered". The "SharedVariableIO" property node gives no access to this property. Does anybody know why? The same question can be rephrased: How can I create a "Single-Process" SV programmatically?
2) The "SharedVariableIO" property node has two items, "Network.OnScan" and "Network.ConnectionType", which have no direct correspondance to any of the properties available in the dialog box. What is the exact meaning of those properties? The on-line help isn't of much use here...
3) Mutliple SV can be edited by using the Multiple Variable Editor (Tools->Shared Varaible->Multiple Variable Editor). A cool feature is the import/export of CSV-files. I am interested in programmatically creating SVs from the information stored in such a CSV-file. Reading the file is no problem, but connecting the file entries to the properties of the "SharedVariableIO" property node would be quite some job. In principle NI has already solved that within the Multiple Variable Editor. I guess there is a bunch of VIs somewhere below "....Program Files/NI/.../vi.lib that do exactly this thing. Does anybody know, if these (which ones?) are available for public use?
   Dietrich
(5,798 Views)
You can't.  The single-process shared variable is an old style LabVIEW global placed under the shared variable abstraction.  There is currently no way to create those on the fly.  Time-triggered also cannot be created programmatically.  I confess I don't know enough about them to know the reason why.
Network.On Scan = read/write hardware? - this allows you to programmatically control when you are reading from or writing to configured hardware.
Network.ConnectionType = connect to hardware even when no one is viewing me? - this has 2 choices, UpFront & OnDemand, UpFront means that the variable will be connected to hardware even when no one is connected to the variable.  This is useful when you want to reserve hardware or when logging is enabled.  OnDemand means that you disconnect from hardware whenever no one is reading the variable.
I would advise against using any of these.  National Instruments can change, or remove, those underlying files at any time as a result of modifications to the MVE.  That could cause issues for any code using those sub-VIs.
Robert
(5,429 Views)
Hi Robert,
thanks for the great answer.
      Dietrich
(5,387 Views)
