Shared Variables deployment failed
Reviving an old thread, but I am having the same issue.
I tried the solutions proposed above but hasn't worked yet.
I am basing off of the example project, "Supervisory Control and Data Acquisition System".
When I try to deploy the cRIO.lvlib in "IO Simulation" I get an error Unable To Start Service.
I will attach screenshots.
Things I have tried:
Repaired Shared Variable in NI Package Manager
Went to "Services" and tried to start NI Variable Engine. Got error, "Could not start due to logon failure". Will attach screen shot.
Message 11 of 15
(717 Views)
Looking at the picture it seems you tried to start the RIO server and not the Variable Engine.
Do you have all the rights on the computer to work on those services?
________________________________________________________________________
Problems will keep comming... Lets hope the answers do that to.
Never give up without a fight...
Message 12 of 15
(700 Views)
Thanks for the reply.
Sorry for attaching the image of starting the RIO server error. I was trying that too.
See attached image for the error trying to start the variable engine.
Error 1068 "The dependency service or group failed to start"
I should have rights to work on the services. Is there a way to check?
Message 13 of 15
(677 Views)
Following this suggestion seems to be helping so far, will check if it solves the issue completely:
https://forums.ni.com/t5/LabVIEW/NI-Variable-Engine-not-starting/td-p/4112216
Open Windows Services, right click "NI PSP Service Locator" service -> Properties -> "Log On" tab -> select "Local System account".
Apply and then start this service.
After that, start "NI Variable Engine" service.
UPDATE: Yes!! That solved it!
Message 14 of 15
(675 Views)
Nice job!
As you can see even the problem looks the same the solution sometimes is different.
I hope this solved your issue and the system is remaining online for you.
Best regards
Message 15 of 15
(628 Views)
