Shared Variables not the same as Variables in IO Server
I have a number of items in my IO Server within a project. Not all of these converted over to being Shared Variables. These are of the type DBL and are read only. They are indicators on my server VI. I cannot use these on my client VI's as I cannot select them on my Shared Variables list (as they do not appear). How can I change this and also make them read/write.
Picture below from DCS IO Server
Picture Below from Shared Variables (Example DBL after cooling does not appear)
(2,481 Views)
It seems that anything that is Read, is not showing up in your second list.  Anything that is Read/Write is showing up.
Where did you get these screenshots?  Any chance it is a list you can select from for a variable that is set up to Write to?
(2,447 Views)
