Shared variables multiplexing
Hello
I'm a newbie in LabView and English is not my native language, so... you know..
I'm re-making a SCADA project in LabView.
I have three equal devices, each of them has about 100 process points.
I want to display process points related only to one device at a time.
In SCADA I have some sort of mutliplexing - it allows me to access tags depending on value of another tag.
For instance in Genesis32: I have temperature tags of three devices: Oven1_T, Oven2_T and Oven3_T. I declare an alias Oven_T, add Oven1_T, Oven2_T and Oven3_T as possible values, and make the alias depending on "theme" - a name of current device.
In the display I put a control bounded to Oven_T and the runtime substitutes the alias with one of the values. I can change the "theme" anytime I want and system re-substitutes Oven_T again.
So, I need to make one display only.
I worked out a solution in LabView: I declare a bunch of shared variables bounded to an OPC server (Oven1_T, Oven2_T, Oven3_T). Then I declare shared variables (Oven_T) for one device only and write (in background cycle) the former variables into the latter depending on another variable.
In other words I made a multiplexer. Then I use my shared variables in a panel that shows state of current device.
The solution seems to work, but maybe there is more natural approach in LabView?
(2,892 Views)
Hi wb,
you should be able to access OPC values using datasocket functions. When using datasocket you will use a string to name the OPC address. And strings can be manipulated using the same approach as in your SCADA system to reference different OPC targets!
(2,877 Views)
Thanks, GerdW
I'll try it
(2,856 Views)
