cross correlation
Hi.
I am a new user of LabView..
I want to determine the time delay between two similar signals, (the values of the signals are record in .tdms file) . I am using cross correlation but the time delay vary a as a function of time (and time delay can be positive or negative) . So Cross correlation can't determine the time delay, it found 0 seconds if I use all the data.
So I want to discretized the cross correlation for different interval of the data (containing a defined number of points), in order to have an ~instantaneous~ time delay as a function of time. I don't know how is it possible..
About the cross correlation, I don't understand why is it exceed 1 whereas X and Y (input variables) are <1 (the signal are normalized).??
Thanks a lot for help!
(3,635 Views)
Hi guys
I have the same problem ...Have you solved your problem?
(3,299 Views)
Yes,
you can use a  while boucle. At any running of the boucle, you fill a matrix (with an determined number of data). Then the cross correlation is perform with the data of the matrix. The cross correlation function is in the boucle.
(3,286 Views)
Sorry that it seems like that something still wrong happens..Could u help me to modify my program?
Thanks a lot!!
(3,279 Views)
