Some build specifications change on different machines
Hi all,
I often need to move my LabVIEW projects from a machine to another one. In this cases, I copy all the contents of my project folder in the new machine.
My projects are built without errors, but some build specifications are not kept.
Build specifications that are not maintained are additional installer list (see attachment).
In the machine 1, I include only Math kernel Libraries and NI VC2008MCMS.
When I open the same project on the Machine 2, all the elements in NI LabVIEW Run-Time engine 2012 SP1 f3 list are checked. (see attachments)
Thank you
(2,434 Views)
Hi AC_85,
have machine 1 and machine 2 the same installed software? Is it the same version? Maybe on the machine on which you copy your project some additional installer is not installed.
You could try to Duplicate the entire project (from project explorer File >> Save as >> Duplicate project >> Include all dependencies) before moving it from machine 1 to machine 2.
Hoping this will help you.
Best Regards.
Cla_CUP
NI ITALY
(2,405 Views)
