Sharing control and indicator values over a shared network
I wanted to know of your thoughts of using shared variables broadcasted over LAN versus the use of XML (with Labview schema) or text based sharing of variables over the same network. Would love to hear about pros and cons of each approach.
Application: A generic VI providing a command over the network to another VI which operates an instrument.
(2,411 Views)
Hi verma456,
I'm not as familiar with some of the text based alternatives but I wanted to pass along one of our white papers regarding shared variables that may give you some of the background you're looking for to see if its a good fit for your application.
Using the LabVIEW Shared Variable
Best,
Tyler C.
Technical Support Engineering
(2,355 Views)
