Shimadzu UV-1800 driver
Hi, I'm wondering if anyone has a LabView driver for a Shimadzu UV-1800 spectrophotometer. Thanks!
(4,462 Views)
Hi Tegula,
NI does not currently have a LabVIEW driver available for that device. However, it may be possible for you to develop a driver for your application. You would need to investigate the communication protocols and commands that the device uses. Then you could create your own driver. This link gives a tutorial about creating your own LabVIEW Plug and Play driver.
Developing LabVIEW Plug and Play Instrument Drivers
https://www.ni.com/en/support/downloads/instrument-drivers/tools-resources/developing-labview-plug-a...
Best of luck on your project!
(4,400 Views)
