‎05-14-2014 01:10 PM
I'm running a test that requires me to output an N-bit word and input a 50-bit boolean array which I need to compare to the expected 50-bit boolean array.
How should I implement storing these "expected boolean arrays" for easy comparison in my 'pass/fail' subvi?
‎05-14-2014 01:22 PM
If you have more than just a very few arrays or if they will change from time to time, store the arrays in a configuration file. There are VIs in the File palette specifically designed for managing configuration files. Look at the help and examples for more information.
The program would read the configuration file at startup (and as required while running) and load the 50-bit arrays.
Lynn
‎05-14-2014 01:23 PM
I would probably store them as attributes of a varient (saved to an xml file) and create an editor for the file as well so when one array changes...... you don't need to rewrite the BD constant
‎05-14-2014 01:40 PM
Store it as an U64, then convert to bool array in the program.
/Y
