Show Controls on TabControl
I'd like to show all Controls which are located on a TabControl. There is a property node for vi's to show controls, but I can't find one for the TabControl.
Is this true??
Thanks for your reply
(3,365 Views)
Hi Kim,
first you have to get the reference from the tabcontrol and then you can read the references from all controls in it.
Mike
Message Edited by MikeS81 on 06-12-2008 03:46 PM
(3,362 Views)
Hi Mike,
Thanks for your reply, but I already tried that.
I can't find the right property node to display on controls on the tab.
Do you know which property node to use?
(3,359 Views)
Hi Kim,
here is an example.
Mike
(3,357 Views)
Thanks a lot!
(3,352 Views)
