Show / Display fuzzy logic firering rule in front panel? (2nd post)
Hi all,
I am using LabVIEW 8.5 with Fuzzy Logic toolkit. I just add the additional output (firering rules" output ) of Fuzzy Controller.vi which shows its block diagram and one can see that it is made up of three  VI's one of which is called inferenz4.vi. Because I find the "firering rules" output on inferenz4.vi. (Following the post in this forums and title "Adding an additonal output node to a VI " at 06-14-2009 10:56 PM) I only can display the firering rule no. (attached 1.gif red circule) in front panel. How can I also display the firering rule no. detail infomation (attached 2.gif) in front panel? Can I show the .fc file (generate in Fuzzy Logic Controller Design)detail infomation in front panel? Thanks
Fung
(2,455 Views)
