Show/Hide sensor in sensor mapping express VI
Hi all,
I'm using and modifing Sensor mapping express VI to develop my application.
I tried to hide/show sensors but without success.
Is there a property node or invoke node to show/hide 3d scene objects?
(2,574 Views)
Hi Fourier,
I don't think there is the possibility to hide/show sensor in Express Sensor Mapping.
While you configure your express VI you need to select sensor in order to map to a model, and reconfigure the Express VI again non in Run-time in order to add/remove sensor.
I'll try to look for a solution, and if I'll find it, I'll forward it to you. But I didn't find any helpful informationsyet .
Best Regards.
Claudio
NI ITALY
AE Dept.
(2,542 Views)
Thank you Cla_Cup.
(2,537 Views)
