Showing pictures together in a window
for my test case , I need to show the graph and measurement details as picture data , I can save pictures this is clear ! but what I can`t is that pasting all the pictures together as one picture to use in my result file.... and instead of seeing Front Panel , I want that the all the pictures (as one picture )  should be seen in this window...
i have a shot , but done with VEE and need to do the same graph. What are your advices?
thanks alot !
Message Edited by Support on 11-13-2007 01:00 PM
(2,829 Views)
First, search the example finder to see some example of how to work with the picture control.
Then, you can use the Get Image method (right click any control and select Create>>Invoke Node) for each indicator to get its image and put those images into a single picture control. You should then also be able to save the picture as BMP, JPG or PNG.
___________________
Try to take over the world!
(2,823 Views)
hello,
you wrote   .....and put those images into a single picture control..... this is my problem to do it, because I have a picture 10 cm*10 cm , I want it like the attachment file over all, the rest below...
thnx
(2,820 Views)
Why not use standard labview indicators for the graph and numbers. Then grab an image of the entire front panel with print screen. Then use image subset to save only the part that you want.
(2,811 Views)
Yes, if you already have the panel set up all you need to do is capture its image. Here's an example VI. Put it inside any VI and it will get its FP and save it to a file.
___________________
(2,809 Views)
