Shunt Calibrate Multiple Channels in One Task - Error 201398
Having created a task with multiple AI Strain Gage channels (each set with same bridge properties and quarter bridge config.), I recieve an error when passing the task to the "DAQmx Perform Shunt Calibration (Strain).vi"
My VI works fine if only a single channel is contained in the task, but more than one channel causes the error.  Do I have to loop through each channel manually?
The "possible reason(s)" varies depending on my approach, but often indicates the AI.Bridge.ShuntCal.GainAdjust being requested is "-Inf"
(3,285 Views)
I'm having the same issue.
(2,973 Views)
You can start a new thread even if you have the same issue. What exactly you aregetting and show us the code for better understanding.
(2,970 Views)
