Signal Generation
Dear Sir
I generate two signals S1 and S2 each having 50 Hz frequency but different magnitude. Phase difference between two signals SI and S2 is 30 degree. Then I multiply both signals to get S1S2 Signal.
Now I want to simulate another signal (S3) whose frequency and magnitude should be similar to S1S2 Signal. However I could not generate similar signal. Please see the attached file containing my NI diagram and suggest the solution. How I can simulate same signal as S1S2?
I shall be thankful to you for your attention and consideration.
Kind Regards
Irfan
(4,518 Views)
Accepted by tronoh
Hi Irfan,
change phase to -60° and S3 will look similar as S1S2!
First: Please define "similar"!
Secondly: when you want to simulate a signal generated by multiplying two sine waves with different phase you should generate it by multiplying two sine waves with a phase offset! Simple math, eh!? (Well, it's certainly no LabVIEW problem then…)
(4,508 Views)
Dear Mr Gerd W
Thank you for your reply. The problem I face is how to equalize the amplitude of S3 with S1S2.
Similar means I want to have S3 same amplitude as S1S2. If we look in the graph S1S2 has amplitude -0.013 to 0.18 (Positve and negative peaks does not have same magnitude). So how we can simmulate S3 with amplitude -0.013 to 0.18?
(4,465 Views)
Dear Mr GerdW
I got it. Thank you for your guidelines.
(4,447 Views)
Hi tronoh,
with more than a hundred messages in the forum by now you should know that providing solutions for questions is the main purpose of this forum.
Do you really think "I got it solved" is a proper solution so others could avoid/solve the same problems?
(4,421 Views)
Dear Mr GerdW
Actually I do trignometric caluclations of S1 and S2 multiplication. So through simple calculation I calculate the frequency,magnitude,phase and offset values.
i.e. SinA SinB = 1/2[Cos(theta1-theta2) - Cos(100t+theta1+theta2)]
Kind Regards
Irfan
(4,410 Views)
