SignalExpress and DSC combination??
Has anyone used the new SignalExpress software in combination with the tag engine to save/record array data from tags??
(3,631 Views)
To my knowledge an interface between SignalExpress and LabVIEW DSC has not been created. There aren�t any built-in features of SignalExpress that allow interfacing to the DSC module and vice-versa.
It is conceivable that this interface could be created since SignalExpress allows calling a LabVIEW VI. A VI could be written which would access data from LabVIEW DSC.
Hope this helps!
Ken S.
Applications Engineering
(3,630 Views)
Ken S is correct. SignalExpress does not support DSC tags. It does support DAQmx Named Channels though in MAX. Not sure if this helps you any.
(3,624 Views)
