Significant Digits in data file
Is there a way to change the significant digits in an LVM data file? I'm using "Write to measurements file"
Message 1 of 11
(6,230 Views)
Depends. What do your "signals" data look like?
PaulG.
Retired
Message 2 of 11
(6,215 Views)
Signals? They're waveforms, voltages...
Message 3 of 11
(6,204 Views)
I'd use the "Write to Sreadsheet File" VI instead. It'll write your results to a text file and you can specify the format.
-CC
"If anyone needs me, I'll be in the Angry Dome!"
Message 4 of 11
(6,172 Views)
I'm not sure I can do it with "write to spreadsheet." It doesn't have a "Saving Data" boolean. A lot of my program is dependent on that. Is there any other way to change the significant digits in a "write to measurements file"?
Message 5 of 11
(6,162 Views)
Put the Write to Spreadsheet File function inside a case structure.
There is no easy way to change the number of digits using the Express VI.  You'd have to convert the Express VI to a regular subVI through the Open Front Panel menu option.  Then you'd have to drill down quite a few levels of subVI's and find where the format string is and change it.  Then you'd have to save that entire hierarchy of subVI's under new names.  I don't recommend any of this.
Message 6 of 11
(6,158 Views)
Accepted by topic author glskinner
Caution! This will change files in vi.lib. I suggest you rename and move the affeted vis (do not blame me if other things break)
Convert the express vi to a vi
Drill to here in the heirarchy
Change this constant format specifier
Message 7 of 11
(6,148 Views)
Jeff, I think I tried this method before...exactly what do I put in the string to output only 3 significant digits?
Message 8 of 11
(6,129 Views)
%.3g
Message 9 of 11
(6,124 Views)
does the semi colon stay?
Message 10 of 11
(6,118 Views)
