Simple File Dialog Question
Using LabView 6i:
When I display the output of the File Dialog all I see is the path to the
folder containing the selected file and not the name of the selected file.
How do I get the name of the selected file?
TP
(3,004 Views)
TP,
The output of file dialog is the complete path to the file, including all directories, and the filename (eg. C:\Windows\Temp\filename.vi) To get the filename only, strip the path off using the utility in the file operations menu.
Good luck
(3,004 Views)
TP;
Are you sure you don't get the name of the file? Make sure the path indicator in the front panel is long enough. If the path string do not fit completely in the indicator, it will look truncated.
Enrique
www.vartortech.com
(3,004 Views)
There also are good examples if you search for 'file name'...on the NI Developer Zone area of this site.
(3,004 Views)
