Simple Game Application
Hello everyone
I 'm Labview begiiner, I have made simple game, but I'm confused to develop it. I want to make additional programs when score: 0-10  with a while loop speed of 3000 miliseconds, when a score of 11-20  with a while loop speed of 1500 miliseconds, and when a score of 21-30  with a while loop speed of 500 milliseconds.
Thanks.
Message 1 of 12
(6,149 Views)
I hope anyone help me.
Message 2 of 12
(6,144 Views)
Accepted by michaelkeane24
Use a case structure in your code:
Also, use data flow instead of a sequence, and use shift registers instead of local variables.
Message 3 of 12
(6,100 Views)
Thank you SIr, but I still don't understand about data flow and shift register that used in this program, what do I get best tutorial about it?
Message 4 of 12
(6,090 Views)
@michaelkeane24 wrote:
Hello everyone
I 'm Labview begiiner, I have made simple game, but I'm confused to develop it. I want to make additional programs when score: 0-10  with a while loop speed of 3000 miliseconds, when a score of 11-20  with a while loop speed of 1500 miliseconds, and when a score of 21-30  with a while loop speed of 500 milliseconds..
  • I think you have significantly more problems, because most of the code seems faulty. Doing bitwise operations in orange wires is a big nono!
  • Your only controls are the baloons, but the two states look identical.
  • An "equal false" is just a "not", and you don't even need it if you would swap the inputs of the select node.
  • Can you explain in simple terms how the game works? How does the user interact with it and what is supposed to happen?
Message 5 of 12
(6,082 Views)
when string indicator give name of color, if you click right color, you get  1, but if you click wrong color, you get -1, it works fine in my pc.
Message 6 of 12
(6,080 Views)
But I don't understand when I try to add this algorithm to my program.
Message 7 of 12
(6,079 Views)
Message 8 of 12
(6,073 Views)
Something like that? try it!
Message 9 of 12
(6,066 Views)
Or slightly cuter. Same difference. (only works for exactly three stages, of course)
Message 10 of 12
(6,063 Views)
