Simple Time Delay in FPGA (cRIO 9073)
Hi all,
Actually i tried the SCL but it doesn't work.
I think that the problem is in the => comparision.
I can send the VI if someone have a cRIO to reproduce the failure.
Message 11 of 12
(714 Views)
You can post a zip file with your project on the forum and I can probably find time to look at it.  What version of LabVIEW is this?  I'm assuming you looked into everything in my last post already.  It doesn't make any sense that the comparison only fails when the VI is loaded from the the 9073's flash.  There's something else going on here.
Message 12 of 12
(704 Views)
