Simple open File then CANCEL Example
Well i'll at least give you a Kudos JR even if the person you helped cant be bothered. Especially as you not only solved his problem took the time to clean up his code 🙂
"Everything should be made as simple as possible but no simpler"
Message 11 of 11
(589 Views)
