‎08-17-2017 01:06 PM
Christian,
Actually the code with only blue wires involved, anyhow exceeds 3 functions (or 2 fun.+1 prop.node) which is the minimum as far I know. Am not saying its not possible, of-course your always welcomed to post such solutions!!
‎08-17-2017 01:09 PM
@PriyadarsiniS wrote:
Yup, Ben.. this was the first thought that came into picture.
Instead, of all this logical method of analyzing we just just straight away make the user right in a string control with artistic liberty, with some limitations written on the *terms and conditions view.
Better an oops than a what if..
Bonus would be it would work on single word palindromes as well, like "radar" "mom" "dad". You would have to use a Trim White space to make it work on palindrome sentences like "madam I am adam".
Ben
‎08-17-2017 01:14 PM
‎08-17-2017 02:31 PM
@altenbach wrote:
@Jacobson-ni wrote:
Or maybe a 0-byte file with the name "2"
I am holding up two fingers. Good enough?
Heck. I can do it with one finger. All you have to do is look at which one I'm holding up.
‎08-18-2017 01:59 AM
Ben, that's not a palindrome sentence.....
"madamIamadam"
"madamaImadam"
‎08-18-2017 03:42 AM
Isn't this case is applicable, if we relate the Input control as String.. Am I getting the point, that's conveyed!!
If not, could you please elaborate it..
‎08-18-2017 03:45 AM
I think its:
madam I madam which would be a palindrome, as Ben said.
If Trim white space is used !!
‎08-18-2017 03:48 AM
I think its:
First: It's not what Ben said.
Second: "madam I madam" is a palindrome even WITHOUT Trim white space......
‎08-18-2017 03:52 AM
Okay, Intaris
You'll be clear, if you see my last reply to Ben..
What I said, was just a suggestion.
‎08-18-2017 03:58 AM
Intaris wrote:Second: "madam I madam" is a palindrome even WITHOUT Trim white space......
The phrase is supposed to be "Madam, I'm Adam". Remove punctuation, white space, and capitalization and you end up with madamimadam.
